HOW TO USE: LCD 16X2
HOW TO USE: LCD 16X2-Uncategorized
Are you a starter with Dasduino? Or a newbie when it comes to electronics? You fancy a specific module, but you don’t know how to use it? Don’t worry, we have our How To Use series!
How to Use is a series of blog tutorials by soldered where you will find everything you need to begin working with your favorite modules. Tutorials include technical characteristics, operating principles, instructions on how to connect the module with Dasduino and basic coding. Everything else is up to you and your imagination.
BASIC CHARACTERISTICS
LCD ( Liquid Crystal Display) is probably one of the most used modules because it is truly useful. It allows you to get any kind of information on an easy-to-read LCD screen. The LCD in our offer has a blue backlight with white lettering. Both LCDs, 16×2 and 20×4, have identical pin assignment and this tutorial is universal for both. Also, the IIC adapter will work with both LCDs.
  • •Size: 16 characters in 2 rows (16×2) or 20 characters in 4 rows (20×4)
  • •Voltage: 5V
  • •Display size: 64.5 x 16 mm(for 16×2)
  • •Size of module: 80 x 36 x 12 mm(for 16×2)
  • •Character colour: white
  • •Background colour: blue
MODULE WORKING PRINCIPLE
Explaining how LCD works cannot be done in only few sentences. It is based on liquid crystals (which, suprisingly, are discovered in 199th century). Each liquid crystal creates one pixel. These are located between two polarizers and they are rotating the light. When a certain voltage faces them, they are correcting themselves and polarization doesn’t rotate the light and passes towards our eye. As a result, we can see active pixels. For all those interested in more details regarding the working principle of LCDs, we suggest an article on Wikipedia.
In this tutorial we will use:
HOW TO CONNECT MODULE WITH DASDUINO (WITHOUT IIC ADAPTER)
Establish a connection using a table above or schematic below – whatever you like more 🙂
HOW TO CONNECT MODULE WITH DASDUINO (WITH IIC ADAPTER)
Before connecting, IIC adapter must be soldered on the LCD display. Insert the adapter from the back of the LCD pins and solder them. The result should be something like the picture below.
It is time to connect the adapter with Dasduino! Fortunately, the connection is now simplified and it requires only 2 communication pins and 2 power pins. Follow the table below or connection schematic.
CODE FOR MODULE
Arduino IDE comes with a LiquidCrystal library that works great but it will only work in the first variant of the connection when the IIC adapter is not used. Therefore, we recommend that you download our custom LiquidCrystal library that works for both connectivity methods. A direct downloading link is here.
IMPORTANT: In the folder where your libraries are, delete the LiquidCrystal folder and copy the downloaded file. Make sure it has the same name.
In a few words we will explain the most important functions of this library. They are already described in the examples of the library and are generally the same as for the LiquidCrystal library:
• lcd.print(); – prints something on LCD. If there is a variable in brackets, a content of the brackets will be shown on the LCD.
• lcd.setCursor(x,y); – sets a cursor (e.g. like one in Word) to a specific position. First coordinate (x) determines the position from left to right (e.g. 0 would be the first character), while second coordinate determines the position from top to bottom (e.g. 0 would be the first row, 1 would be the second row). Example of use: lcd.setCursor(0,1); – sets the cursor to the beginning of the second row. Now we can use lcd.print (); to print something in the second row.
• lcd.clear(); – removes everything what is printed on the LCD
• lcd.home(); – goes with the cursor to the beginning (0,0), but does not clear the screen! (does not work the same as lcd.clear ();)
 lcd.backlight(); – Turns on backlighting
• lcd.noBacklight(); – Turns off backlighting
