HOW TO USE: MATRIX MEMBRANE KEYBOARD
Are you a starter with Dasduino? Or a newbie when it comes to electronics? You fancy a specific module, but you don’t know how to use it? Don’t worry, we have our How To Use series!
How to Use is a series of blog tutorials by soldered where you will find everything you need to begin working with your favorite modules. Tutorials include technical characteristics, operating principles, instructions on how to connect the module with Dasduino and basic coding. Everything else is up to you and your imagination.
BASIC FEATURES
Matrix membrane keyboard is one of the most basic modules. It contains 16 buttons, arranged in 4 rows and 4 columns and we use it as number input to our microcontroller.
Characteristics:
- Maximum voltage: 35V
- Maximum current: 100mA
- Working temperature: -20 to +50°C
- Dimensions: 6,9 x 7,6 x 0,1 cm
WORKING PRINCIPLE
Matrix membrane keyboard uses a combination of 4 rows and 4 columns which determines each button of the keyboard to the microcontroller, Dasduino. Physically, below each button, there is a pushbutton which is connected to red with one end and to the column with the other. You can see these connections in the picture below:
HOW TO CONNECT MODULE WITH DASDUINO
This module comes with female headers which are connected to Dasduino as shown in the picture below. Since Dasduino comes with female headers as well, most simple way to make a connection is to add male headers in between. We can establish the connection with male-to-male cables too.
CODE
A code for Matrix membrane keyboard can be downloaded from the link below. To make it more simple, we used the Keypad library, and code shows an activated button inside a Serial monitor. If you are having any issues regarding library installation, follow our tutorial.
